Most likely a fuel flow restriction. Try removing the small pipe plug from the bottom of the carb bowl. You should get a continous, SOLID stream of gas flowing from the bottom of the carb.
If you get only a dribble of gas look for a restriction. Possible causes: - piece of junk plugging the fuel outlet at the bottom of the tank. (It's usually rust, but I've pulled leaves, pieces of gas cap gasket, bits of rag, etc from atop the fuel inlet at the bottom of tractor tanks...) - a kinked or dented fuel line - if the steel fuel line has been replaced with hose, a partially collapsed hose - a plugged or collapsed screen behind the fuel inlet fitting on the carb. - float level set too high, or float binding in the bowl. - the inline fuel filter you installed may be too restrictive (is designed for a system with a fuel pump, not a gravity flow system as on your tractor.)
Also be on the lookout for an accumulation of rust etc. in the bottom of the bowl obstructing the high speed jet. Even if you cleaned the carburetor, fresh junk can get into it from a rusty fuel line, etc.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
