Re: SW6 International stalls, advice needed
Posted by El Toro on September 26, 2007 at 04:14:54 from (64.12.116.73):
In Reply to: SW6 International stalls, advice needed posted by jmr on September 25, 2007 at 11:30:32:
third party image
I would remove that inline fuel filter if it's not for a gravity fed system. Most are used with a fuel pump. You need to make sure it's a fuel problem when it quits. It could be a weak coil causing the problem when it gets warm.
To rule out the coil pull one the plug wires asap
when the engine quits and see if you still have fire to the plugs. Hal
PS: You may need to open the main jet adjusting screw near the bottom of the carburetor. Like the one on this old B&S carburetor.
