Farmall Tractors Discussion Board
Re: Re: Farmall C questions
Posted by ddg on December 11, 1998 at 08:40:37:
In Reply to: Re: Farmall C questions posted by Stan(VA). on December 11, 1998 at 05:05:58:
In addition to Stan's response I might add the following, If your pump labors & gets hot & drags the eng. down, check this first. On the lower right side of the touch control "head" remove the small hex or allen plug, take out the orfice & cone shaped screen, and make sure the small orfice is not plugged with grit. that's all it takes to screw up the touch control. Also make sure you're using a non-det oil in your system, det oil will foam & your pump will cavitate, & won't have any power
Post a Followup
: Re: Re: Re: Farmall C questions
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
