Re: Farmall Grille , Burger and dessert!
Posted by Bob Kerr on September 27, 2007 at 08:23:28 from (205.188.116.73):
In Reply to: Re: Farmall Grille , Burger and dessert! posted by Fancy Farm on September 27, 2007 at 07:47:01:
They mounted the engine on the right side and had the engine shaft going to a pulley that went to the belt pulley shaft. The freezer ran off the belt pulley shaft with a slip coupler if I remember right. The belt from the engine had a idler pulley on it to put it in "neutral" and if you put the tractor in gear it would go where ever you steered it, but real slow. That is about all I can tell you about this one.
