Re: Magneto and distributor ignition systems
Posted by Bob M on September 29, 2007 at 12:30:06 from (69.205.124.61):
In Reply to: Magneto and distributor ignition systems posted by mark on September 29, 2007 at 09:27:58:
Another advantage is a coil/distributor costs a bit less to manufacture than does a magneto. Thus one rarely sees a magneto on a tractor factory equipped with a battery and generator.
Further expanding on John T's timing comment, a distributor's ability to vary spark timing with RPM results in a smoother running engine over a wider RPM range - and probably also slightly better fuel economy.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
