Posted by Curt in Minnesota on September 29, 2007 at 14:04:44 from (69.42.242.193):
In Reply to: farmall??? posted by DanW on September 28, 2007 at 17:57:31:
The C farmall you bought was also a distillate I guess by the fourth hole in the hood. The one gallon tank appears to have been removed and put on your mower. If you look at the pictures carefully you also have radiator shutters that appear to be in good shape. However, the air cleaner has been remove from the air intake on the carb. The fuel line is also bent out. I suspect who ever ran it last had a problem and that why it has not been used in two years. However, you still got a good deal on it and suspect that the small gas tank and radiator shutter would be of some value to the right restorer. Most of the distillates up hear have been stripped of the shutters and small tanks that make them unique. The C farmall is likely the most enjoyable old tractor to drive and is very handy too (if you don't think so you probably don't own one). Its also very easy to work on. Have fun getting it going.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
