Re: Value of M ?
Posted by Steven f/AZ on September 30, 2007 at 13:50:23 from (24.121.167.138):
In Reply to: Value of M ? posted by Andrew Z on September 30, 2007 at 11:16:10:
Wide or narrow front? A wide front end is worth more, should you ever decide to part it out instead of fixing.
Is the engine stuck? If it's not stuck, is there any compression if you try to crank it over by hand?
With a stuck engine and wide front, I'd say $400 is fair. Narrow front stuck engine I would give $300.
If the engine is loose, it's only a matter of a day to get it running, but rear rubber and rims are pricey so probably only $500 to $600 loose.
That's my $0.02 worth...
