Re: Oil splashing out of Air Intake
Posted by Michael Soldan on September 30, 2007 at 17:18:51 from (24.235.43.4):
In Reply to: Oil splashing out of Air Intake posted by Brian Jensen on September 30, 2007 at 14:40:39:
you have a spark plug wire crossed and the out of sequence firing is causing backfrie through the oil breather, blowing oil out as it tries to fire..check your firing order and the wires to the plugs, once you get that settles it will run..
