Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by Fromjb2 on September 30, 2007 at 18:05:32 from (74.111.119.222):
In Reply to: Full Engine Rebuild or IN-Frame, How do I Know ? posted by ed8844 on September 30, 2007 at 12:41:05:
Hi Ed, how many hours on hour meter or is it broke?
We had a B414D with same BD154 engine and ran it for 15,000 hours and only had a little blow by when under heavy load. We also did proper maintenance and changed the oil regularly and used Rotella T Diesel oil. At 10,000 hrs we changed the main and rod bearing inserts as oil pressure would drop a little when hot. Changing the inserts fixed the oil pressure problem.
Good luck
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
