Re: conversion to 12 v
Posted by El Toro on September 30, 2007 at 18:34:30 from (205.188.116.73):
In Reply to: conversion to 12 v posted by Pat-CT on September 30, 2007 at 18:03:51:
You would need an alternator or 12 volt generator,
may need a regulator, ballast resistor and a 12 volt battery. You would need 12 light bulbs too.
I'm sure I didn't cover all of the things. hal
