Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by ed8844 on September 30, 2007 at 19:09:48 from (74.229.216.165):
In Reply to: Re: Full Engine Rebuild or IN-Frame, How do I Know ? posted by El Toro on September 30, 2007 at 18:21:38:
I'm going to pull The Engine and do it right - Buddy of mine knows a local shop that will check & do the crank and camshaft- they will also hot tank the block. It should be a good tractor when all is done - Thanks guys - Ill let you know how it goes.
Ed
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
