You may be able to get your auto machine shop to measure your rod journals, if you're not comfortable doing it. They should have engine specs on that engine too. If the rod journal are worn, you will need to pull the engine. It would be easier to work on too. Good time to replace all the seals. If that oil pan and engine is sludged up you should have the engine cooked and all oil passages cleaned and blown out for good oil circulation. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
