Re: Oil splashing out of Air Intake
Posted by billde on September 30, 2007 at 19:53:35 from (72.26.91.191):
In Reply to: Oil splashing out of Air Intake posted by Brian Jensen on September 30, 2007 at 14:40:39:
If it is the same as an MD the distributor turns opposite of a gasser. Sure you have the correct firing sequence?
