The compression readings you list are certainly good for an engine that is not running. The plug wiring info in the other posts is important. There isn't any wrong (reasonable) way to put in plugs, I was making sure they were the abnormal looking long reach plugs. intake valves must be moving if you have good compression, exhaust valves might be not opening and compression would still be indicated. A stuck valve will bend a pushrod, then it can snap shut and not open (no pushrod). Pulling the valve cover off and looking at the valve mechanism will be good enough. Pushrods not on rockers is obvious, as are broken springs and components not moving. Set the valves when you are in there (use the book to assure procedure) JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
