Posted by Andy Martin on October 01, 2007 at 07:32:30 from (63.123.95.201):
In Reply to: doing alot of work posted by Pat-CT on October 01, 2007 at 06:55:25:
1 It is not hard to remove the hydraulic pump, just unbolt the control arm, remove filler and all the external pressure ports, then remove the sheet metal shield underneath (if it is there) then the four bolts on the bottom and it will fall out. You might want to sell it.
2 Auto parts stores sell Japanese alternators, research the archives. Why not just use a battery with no generator and keep the battery charged?
3 Removing the PTO and belt pulley are not hard, other than draining the fluid and refilling to get the PTO off. Fabricating plates to close the openings is hard. The belt pulley consumes no power until it is engaged and the PTO consumes very little. You will gain more hp by leaving the generator off than by removing the PTO.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
