Re: doing alot of work
Posted by Steven f/AZ on October 01, 2007 at 08:25:44 from (216.67.213.217):
In Reply to: doing alot of work posted by Pat-CT on October 01, 2007 at 06:55:25:
I"m assuming that you want to remove those items to save weight... right?
Making a plate to cover the openenings should be easy... if you have some basic fabrication skills. The rear PTO will just pull straight out once you get the bolts out - same with the belt pulley drive, straight up once the bolts are out.
Be careful lowering the hydraulic pump - it"s heavy! Just unhook the drive coupler and remove 4 bolts and it drops.
