Re: MD stopped running
Posted by Doug N on October 01, 2007 at 15:21:23 from (64.12.116.73):
In Reply to: MD stopped running posted by Tim Mylrea on October 01, 2007 at 15:05:45:
Sounds like it jumped cam timing. Is it a mag or distibuter? Start by pulling the cap off, and tap it over to #1 compression and see if the rotor lines up with the #1 spark plug wire. If not, then you will have to pull the front of the motor apart to see what let loose. Doug N
