Re: SOP for Pull Starting a Tractor
Posted by Janicholson on October 01, 2007 at 20:24:26 from (66.173.50.5):
In Reply to: Re: SOP for Pull Starting a Tractor posted by Brian Jensen on October 01, 2007 at 20:09:27:
If it has a loader it means lifting the loader and chaining it so nothing will make it fall down.
See my other post for info on Valve adjustment. You will still need the specs, they should be found to the left in tune up guide. I also agree that patience is a virtue, and putting it back in the building not running is pretty hard to do. Getting it started on gas is the real ticket. JimN
