Re: SOP for Pull Starting a Tractor
Posted by Janicholson on October 01, 2007 at 20:34:58 from (66.173.50.5):
In Reply to: SOP for Pull Starting a Tractor posted by Brian Jensen on October 01, 2007 at 19:43:26:
The only reason we have not suggested slipped or damaged timing gears is because of the compression readings. Spark plug wires need to be (probably if the mag or distributor is in standard location and not botched up)
3-1
4-2
this is looking at the cap from the back of the tractor installed where it belongs. JimN
