Re: SOP for Pull Starting a Tractor
Posted by JT on October 02, 2007 at 06:34:16 from (70.226.238.129):
In Reply to: SOP for Pull Starting a Tractor posted by Brian Jensen on October 01, 2007 at 19:43:26:
As far as I know about this subject, you cannot pull it far enough to get enough heat in it to start a dual fuel tractor on diesel only. You have to have the engine running on gas and that will be the only way to build the heat in the engine needed to run it on diesel. Now, I may not be 100% correct, but from what I know about these tractors, this is the only way it will get enough heat to run a diesel engine.
