Re: Valve Adjustment Saga
Posted by Janicholson on October 02, 2007 at 13:20:43 from (199.17.6.122):
In Reply to: Re: Valve Adjustment Saga posted by Brian Jensen on October 02, 2007 at 13:14:53:
The feeler is placed between the tip of the valve stem, and the rocker arm. A light drag when no twist or bend is on the gauge is perfect feel. Just tape up the hose to keep it from bursting. Duct tape in narrow strips is great.
Do not use more than 6 psi!! Best of luck, JimN
