Re: Valve Adjustment Saga
Posted by Brian Jensen on October 02, 2007 at 13:14:53 from (207.176.229.92):
In Reply to: Re: Valve Adjustment Saga posted by Janicholson on October 02, 2007 at 13:06:37:
Thanks Jim,
I will go out and take a couple pics of the coolant areas, there is no coolant in the oil and it was not mixed in the oil at all there was just 2 small pools of it in 2 of the the bolt recesses. I realize I need to use a flat feeler guage to adjust the valves, I am just not sure where to use the feeler guage. I guess I could just google the procedure for valve adjustment but I prefer learning these things from you guys. If it is a cracked head who would I take it to for repair, or how would I make the repair? I will pressurize the rad and see what I can find, I will have to replace my upper rad hose first though as I am not sure it is totally split or not.
