Re: Farmall H with a miss
Posted by Janicholson on October 02, 2007 at 13:39:28 from (199.17.6.122):
In Reply to: Farmall H with a miss posted by dan.160 on October 02, 2007 at 13:31:30:
Gap is .020" not5 15.
Make sure the shaft has no play in it side to side. if it does, it will not run correctly. Wires are:
2-1
4-3
When looking toward front of tractor and cap is on.
If misfire persists, pull off one wire at a time to find the mis, then change the plug to a different cylinder to see if the mis follows the plug. If so get a new one. If not check compression, and valve adjustment. JimN
