Re: Gasoline and wiring Farmall A
Posted by Janicholson on October 02, 2007 at 18:30:51 from (66.173.50.135):
In Reply to: Gasoline and wiring Farmall A posted by history guy on October 02, 2007 at 17:56:13:
If your A has a four position switch, LHDB, and a cutout relay on the generator. (no voltage regulator) you would need to rewire the whole charging system to go to a three position sw.
The switch shown on Ebay(if you use it) would have one connection to the tail light, one to the headlights, and one to the power (from the Load side of the Amp gauge, or the L terminal on a real voltage regulator. The dim position goes through a resistor to the headlights only. Only lights of the original brightness/wattage can be used because the resistor overheats with bigger drawing lights. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
