Posted by Janicholson on October 04, 2007 at 05:54:58 from (199.17.6.122):
In Reply to: 12 volt bulbs posted by billde on October 04, 2007 at 05:26:52:
yes. Any bulb that will fit behind the lense and have the common bayonet base. There are many. (there are archive numbers in -search for- above. It is important to avoid the use of the original light switch, or use a relay in the circuit to keep from overloading the dim resistor on the switch. Mounting seperate lights with a heavy duty switch, supplying it with amp meter voltage through a 15 amp inline fuse will also work. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
