Re: Whats Worth More SA or SC
Posted by terryjd on October 05, 2007 at 08:15:35 from (69.159.75.227):
In Reply to: Re: Whats Worth More SA or SC posted by scotty on October 04, 2007 at 17:11:59:
Hi Scotty
Your right 6 volt start great in the winter. About the only reason I am going to change to 12 volt system is the generator tested as no good, already blew a new $40.00 amp meter I just bought and installed in the tractor when the genny decided to over charge. Now this might have been caused by the new $40.00 voltage regulator I just installed also because the tractor wasn't charging. So is a chance the regulator is bad also.
I have the stuff laying around to do a converserion just had to buy another amp meter for it, this time just bought a $17.00 amp meter instead of one that says IH on it. Figure convert it would be cheaper then getting genny rebuilt, taking chance on other parts being bad. Once converted I will have a 12 volt neg, ground system that I understand instead of a 50+ year old genny system I don't.
