Re: 706 Rear-end noise
Posted by Randy in NE on October 05, 2007 at 10:25:04 from (204.124.193.191):
In Reply to: 706 Rear-end noise posted by Max Adams on October 05, 2007 at 07:57:53:
It could be the pto like you think but I would think that the pto wouldn't cause much noise unless you engaged the pto. It could be something as simple as the axle clamp bolts not being tight. You might want to take a big wrench/socket and check them. Check both sides and maybe jack the tire off the ground so that you can spin the wheel and check for tightness at several different positions. If it has been sitting for a long time there is always the possiblity of a bearing going out on the axle. It isn't fun but it would probably be cheaper in the long run to start taking things apart to see what is in there.
