Posted by Owen Aaland on October 05, 2007 at 12:03:43 from (65.174.247.81):
In Reply to: Re: 706 Rear-end noise posted by Randy in NE on October 05, 2007 at 10:25:04:
If the PTO drive shaft were not installed correctly, the noise would be present whenever the engine was running. Drive train noises appear only when the tractor is moving.
If you do not find a loose wheel or hub, jack up a wheel and spin it, listening for any unusual noise. Compare the noise between the sides. Gear noise cab usually be picked up at slow speeds, bearing noises at higher RPMs. Since you did not hear it until you moved it a higher speeds, I wouls expect a bearing problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
