Posted by Joshua Lawton on October 05, 2007 at 12:48:23 from (199.64.0.252):
In Reply to: farmall H starter posted by Askew on October 04, 2007 at 17:01:39:
Askew,
I had the same problem and it was the ring gear on the flywheel. If you pull out the starter, look in the hole in the housing with a flashlight and you can see the teeth. If you can turn the flywheel you will be able to see all of the teeth. Some of them may be chipped, worn, or missing. It's a relatively easy job to do if you have some mechanical aptitude and some special tools to split your tractor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
