Posted by Janicholson on October 05, 2007 at 14:42:23 from (66.173.50.187):
In Reply to: Re: Hydraulic Update posted by El Toro on October 05, 2007 at 11:56:45:
Hal, Copper tubing is not supposed to be used for hydraulics. It often is, but it is not safe to do so. most low pressure systems (under 1500PSI) use 1/2" ID hose fittings and flares. All tubes are steel, or alloy, and hose needs to be rated at 2500PSI to be within expected peak pressures. Copper tubes work harden and crack regularly. Just being safe, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
