farmall c runs hot
Posted by dennis repaal on October 05, 2007 at 16:28:25 from (71.82.155.95):
just put radiator back in from raditor shop he said it was all right. flushed radiator with it hook up to motor so block should of got cleaned out to.un-screwed drain plug hardly any junk came out.no water in oil.what pressure raiator cap do they run on siphon system.any help i would greatly appreciate. thank-you.dennis
