Posted by El Toro on October 05, 2007 at 16:47:27 from (205.188.116.73):
In Reply to: farmall c runs hot posted by dennis repaal on October 05, 2007 at 16:28:25:
I would check to make sure there's no thermostat has been installed. Check your timing to make sure its not retarded. Some of those engines get a buildup of rust and dirt around those wet sleeves that prevents the coolant to get near the sleeves to cool them. It may help to install a water pump that will circulate the coolant. Hal PS: I wouldn't keep running the engine if the temp gets too high. You can crack a head very easily or worse.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
