Re: F 12 crank
Posted by moseed on October 06, 2007 at 06:38:10 from (207.177.239.36):
In Reply to: F 12 crank posted by 52G on October 05, 2007 at 12:38:26:
You'll be hard put finding nos original bearings. An option is to have your crank ground .002 and get the .002 over bearings from Rice. The problem there is the two shells (for each juornal) will be the exact same. They will not match at the notches when you install. You'll have to gring your own notch. Yes it is a pain.
