Posted by CENTAUR on October 06, 2007 at 13:19:08 from (71.154.210.75):
In Reply to: H Carb question posted by Mike CA on October 06, 2007 at 11:50:41:
What make and model is it?The washer you describe may be an air bleed which is not something to tamper with.Instead use high volume,high pressure air and blow back through the orifice after running carburetor cleaner through it in both directions.The wetter the air the better it will remove (CRUD). Is the BODY and AIR HORN made of cast iron or zinc? CENTAUR
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
