Re: Super C fast hitch/ broken cast :(
Posted by Jim Broughton on October 06, 2007 at 16:22:37 from (4.243.28.113):
In Reply to: Super C fast hitch/ broken cast :( posted by Andrew Z on October 06, 2007 at 16:07:10:
Andrew; I understand that there is rod for arc welding cast-iron...but I haven"t tried it on anything big or heavy. If you acetylene weld it (braze) you will need to heat the broken pieces up before welding...if you are unsure how to do it, take it to a reputable welding shop and let them weld it for you.Properly done, it should last a long time .
Best of luck.
Jim B.
