Re: IH 1100 mower
Posted by GordoSD on October 06, 2007 at 19:36:45 from (66.115.200.140):
In Reply to: IH 1100 mower posted by Moline_guy on October 06, 2007 at 18:47:49:
I use the 1100 mower exclusively. Never had a crack where you have had. I suspect the lift lever rod is out of adjustment. Also check the outer shoe for position. And check the weight of the bar. Its supposed to be about 60 lbs when set up right. Do you own the manual. Your IH dealer can get one for you.
Gordo
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
