Re: No Spark Farmall A
Posted by ScottyHOMEy on October 06, 2007 at 23:53:06 from (71.241.214.74):
In Reply to: No Spark Farmall A posted by history guy on October 06, 2007 at 20:55:43:
Did you get both wires hooked back up to your condensor without the connectors shorting? Are both insulators where the post on your condensor passes through the body of the mag in good shaspe and in place? And is the wire from the points to the condensor good. Check if for continuity. Sometimes,also, it will chafe and wear and cauuse a short where it passes through to the condensor.
