Re: No Spark Farmall A
Posted by gene bender on October 07, 2007 at 00:09:23 from (67.55.226.214):
In Reply to: No Spark Farmall A posted by history guy on October 06, 2007 at 20:55:43:
Sounds like a common mistake that the rotor is not lined up with the tower when the mag impulse fires. Just remove the mag cap and turn the engine over slow with the crank. When the rotor stops just before top dead center is the rotor lined up with the tower. You mite have to remove the screws and move the gear that turns the rotor so it lines up with the tower when the mag impulses.
