Posted by Janicholson on October 07, 2007 at 10:26:10 from (66.173.50.113):
In Reply to: Farmall A Piston Help posted by J-Green on October 07, 2007 at 10:01:42:
Increasing the power of an A is nice, but not necessary. The increase to 123CID is easy, and the use of domed pistons will be even better. Efficiency is increased by increased compression, so total economy will be incrementally better. The use of unleaded regular fuels will be fine with the bigger bore and dome pistons. unless head shaving, and other specialty efforts raise the compression pressure above 155osi or so. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
