Re: Supper C starter
Posted by ScottyHOMEy on October 07, 2007 at 13:05:18 from (71.241.214.74):
In Reply to: Supper C starter posted by Larry in GA. on October 07, 2007 at 12:45:29:
No, it's pretty straightforward. It'll pull straight out, and it'll slip right straight back in. Shouldn't be anything to line up except the two bolt holes, and make sure the open part on the inside faces the flywheel so the gears can connect.
Only caution I'd toss in is to disconnect your ground before removing the hot cable from the battery to the starter hot post. That's just to avoid some major spitzensparkin, fuzenblowin, framenweldin, batteryblowinuppinshort if the hot cable should ground out. The ground cable on the SuperC is short and dependin' on what you have for a riggin' it can be a pain in the neck. Mine is such that I take the ground cable off both ends, batt and chassis, to make sure it can't possibly connect.
