H hydraulic liftall question
Posted by Scott Rukke on October 07, 2007 at 14:15:34 from (67.183.230.71):
I am installing a 2-way valve so that I can operate a back blade with power up and power down. My question is about the liftall control rod and pump. Is it OK to leave the rod and pump operating continuously or will this damage the pump. My valve has a return line but the relief is set at about 2000psi. I am not sure I can get the relief down much below this set point. Is there an internal relief on the liftall?
