The lift all has a relief (much lower than that, less than 1000psi) the lift all control rod can have a new little detent brazed to the under side to hold it back in the on position. As long as the valve you install is an open center device, when the valve handle is in the middle, it will be fine. When not using the hydraulic, it is probably good to put it back in the hold position of the stock detent stub. Plumb the return line into the bottom drain plug with a T. the use of a T on the fill plug causes oil to come out the cap. If the devices use two way cylinders, and you check the oil as they get used to working, all will be fine. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
