Posted by ddg on October 07, 2007 at 14:46:35 from (64.12.116.73):
In Reply to: Farmall A Piston Help posted by J-Green on October 07, 2007 at 10:01:42:
I rebuilt my SA a couple of years ago, and wondered the same thing. I had the head planned enought to square it up, and had it completely rebuilt with new valves & guides. they re-ground the coutour on the rocker arms where they contacted the valve stems, and shimmed some of the springs. It got new valve seats too. Just like a new head. The pistons in mine were the old cast iron pistons with three upper & one lower ring. I went with the bigger bore and lighter aluminum step tops. I was worried about it being harder to crank, but it was not noticeable, it starts on the first lick now, never did that before. Enough power to mow tall grass in 3rd with the old Woods L59. Using whatever pump gas I want, and 10-30 oil. I also put in new main & rod bearings at the same time, runs like a new one maybe better. (1948 #250559)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
