Re: Starting Tank for H w/heat shield
Posted by dej(JED) on October 08, 2007 at 07:47:20 from (69.40.138.58):
In Reply to: Starting Tank for H w/heat shield posted by dan.160 on October 07, 2007 at 18:16:17:
A true distillate actually contains some gasoline fractions, so running diesel will be a real challenge. I don"t expect that it will run very long.
