Posted by Theman on October 08, 2007 at 13:10:01 from (65.248.77.5):
In Reply to: Farmall M help posted by Help! on October 07, 2007 at 20:10:22:
Remove the spring that returns the clutch pedal then disconnect one end of the reach rod outside the housing that goes from the clutch pedal to the pivot shaft. The throwout bearing can then come forward off the carrier. The bearing will be pressed on the cast iron sleeve with the two bosses. A good auto parts store that does automotive machine work can replace the bearing for you if you don't have a press for it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
