Need Cam Gear Replacement info
Posted by Brian Jensen on October 09, 2007 at 07:24:38 from (207.176.229.92):
Does anyone have a manual for a D264 that they can copy the section on replacing the cam gear. I am trying to play beat the snow with this little project and do not have time to wait for a manual to be shipped from the US to Alberta. Any help or info on an online source would be greatly appreciated.
Thank You.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
