Sick hydraulics on 140
Posted by Tab on October 09, 2007 at 17:16:15 from (4.252.34.111):
I attempted to plow up the garden spot today, and used my quick-connect disk(that I think is too heavy for the tractor). Back end of disk was dragging, not up as it should be. Took the disk off and put my 2-bottom plow on. Hyro didn't want to pick it up. Real slow responding. It usually jerks that up quick. Noticed that when the hydro lever is in a neutral position, rock-shaft had a little "automatic" movement. not much, but like a mild case of Parkinson's disease. Is it time for a hydraulic re-build? Do I need to keep that "too heavy disk" off of my 140? Thanks for any help....Tab
