Cub problems again
Posted by Farmallb on October 09, 2007 at 18:22:00 from (64.149.56.71):
With new rings, on 23 cyls I get no compression, on the other 2 I get 50 and 65. I have been told about ring glaze. I cleaned around the grooves good, but is that all there is to this glaze thing?? Im told if one of the top rings is turned upside down, it wont draw gas. It starts, and runs for awhile, not right, and smoking all the time. It wont stay running, as if someone has open up the gas, started it, then shut the gas off allowing it to starve. I never did anything with the valves when I had the head off, HELP
