Re: Cub problems again
Posted by billde on October 09, 2007 at 19:24:39 from (72.26.91.191):
In Reply to: Cub problems again posted by Farmallb on October 09, 2007 at 18:22:00:
The glaze thing refers to glazing of the cylinder walls, they must be honed to remove the glaze.
What was your piston skirt clearance?
Do you have the proper ring end gap?
do you have the tappets set correctly?
Have you done a wet compression test?
