Re: 12 volt or 6 volt
Posted by Andy Sommer on October 09, 2007 at 21:37:44 from (216.49.120.23):
In Reply to: Re: 12 volt or 6 volt posted by Bob Kerr on October 09, 2007 at 21:19:38:
I had to laugh at the last one!!! I did read where 6 volt cables need to be heavier. I'll try just to clean the points, when I disassembled it last winter, the plugs and wires may have found the trash. Have everything else though. I see what I can do and ask more questions later.
